need some help here!
Old Feb 20, 2005 | 02:10 PM
Tyson150's Avatar
Default need some help here!
i just got my 14t sprocket and i went to take off the case savor and i couldnt get the bottom screw to come undone. i already broke one socket wrench...is there any lubricant i can put on the screw to make it loosen alittle. anybody have any suggestions?
Old Feb 20, 2005 | 03:13 PM
hondabuster's Avatar
Lubricant wont help, if the head of the bolt is tight against the case saver. Somehow the lube needs to seep behind the head, and make it to the threads. It wont hurt to try.
Try using a 6 point socket, instead of a 12 point.
Old Feb 20, 2005 | 08:56 PM
dzzy's Avatar
If you still got it together enough to ride it may help to get the engine hot.
Old Feb 21, 2005 | 07:08 PM
OutRacing's Avatar
Use a torch, heat around the screw, but not the screw, spray some wd-40 on there and take it out.
Old Feb 21, 2005 | 07:42 PM
robbls's Avatar
Outracings advice is a little scary.
1. A torch can damage your aluminum case.
2. WD40 is VERY flammable.
