Turbo help!?!?!?!?!
Old Feb 22, 2005 | 12:48 AM
thumper650's Avatar
Default Turbo help!?!?!?!?!
I am getting a turbo for my DS and i was wondering how much of a extended swing are you have to got. im am just running a turbo not race gas or any thing like that.
Old Feb 22, 2005 | 02:14 AM
crackerJack's Avatar
Turbo/efi?? how many pounds of boost. Are you buying a kit or building it yourself. If not race gas or alcohol, are you planning on running pump gas??
Old Feb 22, 2005 | 07:13 AM
azsandrider's Avatar
I have the KMS Turbo kit with 5 pounds of boosts and have a stock swing arm. If you stay at a low boost and know how to ride, there should be no problem.
The front end comes up like a dirt bike, which cansave your butt at times.[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 22, 2005 | 02:07 PM
BigDogAZ's Avatar
I run up to 9 lbs of boost on race gas and Alcohol and run a stock swing arm. Like azsandrider said its like a dirt bike, very predictable.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 22, 2005 | 08:26 PM
thumper650's Avatar
how much boost can you run on a stoke ds and how much boost can you run with out race gas?????
Old Feb 22, 2005 | 10:10 PM
budtbaar's Avatar
I'm waiting as well for Kelly to get the turbos in. I went ahead and put on a +5 Ace fab swing . bone stock the bike rides very nice more useable travel
looks cool too
Old Feb 23, 2005 | 12:45 AM
thumper650's Avatar
how about a cluch and what kind????
Old Feb 23, 2005 | 01:06 AM
I would not run a turbo without higher octane fuel. Even 5 lbs of boost would most likely cause problems. I had some problems at 6-7 lbs of boost with 110 octane. If the fuel mixture was always spot on maybee you could get away with it but the previous set ups needed a little forgiveness for mixture problems. There are alot of people with more knowledge on the subject and a more objective answer to your question.
Old Feb 23, 2005 | 09:14 AM
Majorecho's Avatar
you could probably get away with running premium and 5 lbs of boost with a low compression piston.
ReconBayou
Oct 31, 2022 05:37 PM
Logan Collins
Sep 5, 2015 08:03 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
DSBUDDY
Dec 28, 2001 01:43 AM
