ALL the lights burnt out on 95 explorer
Old Feb 23, 2005 | 07:06 PM
Fastblasterboy's Avatar
Default ALL the lights burnt out on 95 explorer
My dad's 95 explorer has some problems. ALL the lights on the thing burnt out. Even the ones on the headlight and even the 4x4 light. What could have caused this?
Old Feb 23, 2005 | 07:20 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
circuit breaker
Old Feb 23, 2005 | 07:30 PM
95sport400's Avatar
Or running without a battery.
Old Feb 23, 2005 | 08:27 PM
Is that the thing under neath the headlight by the oil tank under the plastic? the circuit board is bad? are the expinsive?
Old Feb 23, 2005 | 09:55 PM
Smitty4's Avatar
Usually, when that happens it's due to a voltage regulator failure. I had it happen on a CBR600 that I used to own.
It kept burning out headlight bulbs, one after the other. Then it cooked the battery. (rotten eggs!! P.U.!! [img]i/expressions/face-icon-small-shocked.gif[/img])
After I replaced the battery, my multimeter was reading 21 volts @ idle @ the battery!!!! [img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img]
Old Feb 23, 2005 | 11:07 PM
95sport400's Avatar
There is no voltage regulator. They use the battery for that. That's why you can't run 'em without the battery.
Old Feb 23, 2005 | 11:10 PM
GeorgiaBII's Avatar
There has to be a voltage regulator. Now they can use the battery as a load regulator but the alt has to have regulation to control the voltage. The battery will not do that.
4060133 RECTIFIER,LR-37
That converts AC to DC and also limits the voltage.
Old Feb 23, 2005 | 11:22 PM
ftwflh's Avatar
You have a bad battry and/or a bad ground.A cell bad in a battry will cause a power surge blowing all the bulbs.A loose main ground will do the same thing.
Old Feb 23, 2005 | 11:36 PM
110Wearwolf's Avatar
on my dirt bike, if one light burns out soon after the other one burns out
Old Feb 24, 2005 | 12:01 AM
Is there some sort of fuse that could have blown that i need to replace?
