question about my 14t sprocket...
Old Feb 25, 2005 | 09:02 PM
Tyson150's Avatar
Default question about my 14t sprocket...
i installed my 14t sprocket on yesterday and it wobbles a little, not much at all, but just a little. do you think when the chain is tightened it will not wobble. another question.... which side to i put the sprocket on. on one side it is flat and on the other side it bulges up alittle. the stock one had the flat side on the outside....if that makes sense. just making sure cause i dont want to break anything....thanks
Old Feb 25, 2005 | 09:33 PM
LTZ's Avatar
LTZ
I don't think it should wobble at all!! Maybe a little play in the shaft but not the sprocket. Make sure it is seated all the way and recheck your bolts, put loc-tite on 'em and torque 'em.
Old Feb 26, 2005 | 01:52 AM
nosliw's Avatar
yea i just took off my sprockets and chains to clean them yesterday. the front sprocket having a small amount of play is normal. you just dont really notice it until you take it off, and when your working on your quad your nervous you might brake something so any little doubtfullness really gets to you. as for position is goes on, it should say 'OUTSIDE' on the part that should stick outside and vice versa
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
