I cant get my spark plug out!!
Old Feb 28, 2005 | 12:24 PM
AustinONeal's Avatar
Default I cant get my spark plug out!!
my plug is stuck how the hell do i get it out i used the supplied tools, nothing a little help
Old Feb 28, 2005 | 12:28 PM
wheelinguy2003's Avatar
get real tools....the ones that come with are like emergency on the trail use....you need a real rachet and socket if it is stuck that bad...hope this helps
Old Feb 28, 2005 | 12:36 PM
oh...by the way...an 18mm deep will fit...i had to use a 1/2in stuff.....good luck
Old Feb 28, 2005 | 01:27 PM
i used the real deal tools too no luck
Old Feb 28, 2005 | 01:36 PM
DLRPLATE's Avatar
is it stiprd out? If so try getting a size smaller 12 point socket and tap it on (make it fit) with a hammer. Sometimes going to a standard size smaller works better. This has worked for me.
Old Feb 28, 2005 | 01:42 PM
1LeSSRaptor's Avatar
You should be able to feel the socket fit on the plug correctly. If not, if the socket keeps slipping off of the nut on the plug, then there is something in the plug chamber. On mine, I had a piece of a screw sitting next to one of the sides of the nut and the sleeve is only big enough for the socket to fit, so it was slipping off of the nut. Pull the plug wire and turn off the gas. Flip the quad from the rear end up and whatever is in there will come out. You may have to tap it a little. If it's fitting on the nut good, then it's just really tight, so you'll have to either get bigger muscles, or use a cheater bar. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 28, 2005 | 02:16 PM
86LT250RFatty's Avatar
let me guess, you got the plug out, but its just floating around and you cant get it out of the head, to get it out then, use the ignition coil, press it onto the plug then pull er up.........
Old Feb 28, 2005 | 03:25 PM
no i got a socket to fit it fine and everything i even beat on it with a hammer still it wont give, get it hot nothing . i think its just the really high octain gas i was running kinda welded it. but i know it will come off im just afraid of geting to rough with it and screwing something up
Old Feb 28, 2005 | 03:27 PM
make sure your turning the right way . . . .counter-clockwise
Old Feb 28, 2005 | 04:23 PM
caliraptor's Avatar
Sounds like the spark plug seized in their. You will probably get it out, but its gonna come out with the threads off the head. Goodluck!
