TM45
Old Feb 28, 2005 | 04:06 PM
cline's Avatar
Default TM45
I finally got my TM45 installed and the guys at my shop said they have never played with this carb, well i got it back and ready finally and it almost feels like i lost a little bit of power in 2nd gear, i remember how easy it was to get my wheels off the ground in 2nd, and now its not very easy at all...but 3rd-5th the power feels really impressive...it also dies if i let it idle for a little while, and also it seems like its a little groggy sometimes..is this a jetting issue or what?
Old Feb 28, 2005 | 04:14 PM
BigWaynester's Avatar
Default TM45
What is your jetting now? Do you have the Acc Pump activated?
Give us some details, needle #, clip position Main and pilot jet.
Old Feb 28, 2005 | 07:01 PM
Hightower's Avatar
Default TM45
yes that's a jetting issue, more info and we can help!
bike is all stock? what about pipe?
plus everything Wayne said
Old Mar 1, 2005 | 12:15 AM
thebigshow's Avatar
Default TM45
chad, if u still have the same jets in it that i had in it when i sold it to ya....it is going to be way Rich..you proberly are going to have to go down a size on your pilot jet, and a couple of sizes on your mains. i think i have the needle in the 2nd to richest position, u are proberly going to have to move it up a slot or two....
so i take it your smoking problem went away with the change of the carb...glad to hear you dont have to tear it down....
Old Mar 1, 2005 | 03:36 PM
cline's Avatar
Default TM45
the bike is all stock except for TM45 and ported intake, havent got to order my end cap yet. big show, whatever jet you had in it before, they went down 10...how do i get to the needle to change it? yes the smoking problem went away, and it tears it up quite a bit more than stock, but i know im still not gettin the max out of this carb, so im still a little down about that, but hopefully it'll be fixed sooner or later...
Old Mar 1, 2005 | 04:14 PM
sam's Avatar
sam
Default TM45
the end cap is going to be a big help, the ds is tuned for the stock carb and stock end cap, putting that bigger carb on is going to shove more air and gas in her but it cant get out any more than w/ the stock carb.
to get the needle out you will need to take the cap off the top of the carb, twist the throttle to make the slide come up and put a screw driver or something under the arm to lock it in plase to keep it from going back down. and take a small phillips and unscrew the locking clip that holds the needle down then take a needle nose and pull the needle out. good luck
Sam
Old Mar 1, 2005 | 08:03 PM
thebigshow's Avatar
Default TM45
i think the top of the slide has a small metric allen head bolt on top of the slide . just loosen it up a bit and push the hook part off the slide.when u pull the needle out make sure u dont loose the plastic washer under it..
Old Mar 1, 2005 | 11:34 PM
sam's Avatar
sam
Default TM45
yah your right my bad...
Old Mar 14, 2005 | 12:17 AM
cline's Avatar
Default TM45
i just got back from riding and i noticed that if i had my rpms up and then let off the gas all at once some smoke pours out of my exaust maybe a 3 foot trail from the end cap. should i be worried?
Old Mar 14, 2005 | 12:19 PM
sam's Avatar
sam
Default TM45
Cline,
Ru running a mod end cap, no lid air box? also do you have your jetting ? also do you know if the acc. pump is activated?
