wheels spacers for mx racing
Old Feb 28, 2005 | 11:47 PM
Yellr400EX's Avatar
Default wheels spacers for mx racing
Will wheel spacers work until i save up for +2 arms cuz i dont remember where but i heard that spacers can cause things to break and bend there not gonna be permanent juss till i get more money
Old Feb 28, 2005 | 11:51 PM
CTATV's Avatar
Im not sure id wait for other people to respond but I have spacers on my wolverine and i have had no problems, but i dont jump much so that may be a big factor.
Old Mar 1, 2005 | 01:19 PM
maddog56's Avatar
Wheel spacers will just delay you getting new a arms and axle by costing you $$$. Run stock and forget the spacers, just save up for the right parts.
Old Mar 5, 2005 | 11:38 AM
mahnster's Avatar
Definately stay stock until you get extended a-arms.
Old Mar 10, 2005 | 11:09 PM
exracer131's Avatar
i would run the wheel spacers as long as you dont leave the ground more than one inch when jumping. there is no cheap alt. to wider a-arms and axle, i dont care what anyone says. put the spacers on if you want, but dont be surprised when one of your wheels come off after a landing a good size jump.
Old Mar 12, 2005 | 05:51 AM
dual-sporter's Avatar
on the front,
i've seen some racers with spacers. they cause additional wear & stress on the ball joints and wheel bearings. additionally it adds more leverage to the shock, making it easier to bottom out. they also affect steering geomtry, adding more bump steer.
my opinion... skip them & save your money, it's not worth burning up your hard earned $$$ (on maintenance too) & delaying getting good components.
on the rear,
you can usually use spacers w/o problems, it just makes it slightly more likely that you may bend or break a stock axle when jumping hard.
if you get the $$ to do the front but not enough to put a good axle in, you can put spacers in the rear, and then save for an axle.... but don't widen the rear alone, the quad will not feel balanced in corners....
you'll be farther ahead just saving up for good gear.... run what you got for now.
Old Mar 12, 2005 | 04:04 PM
Banshee392's Avatar
Originally posted by: dual-sporter
on the front,
on the rear,
Wow, couldn't of said it better. Nice job!!
Old Mar 12, 2005 | 05:04 PM
Yellr400EX's Avatar
thanks guys
Old Mar 13, 2005 | 05:06 PM
schonertkyle's Avatar
3 of my friends raced 2 years of MX with spacers on them and took 2 years to bend an axle. And 2 out of the 300 are still using stock a-arms and havent bent ne thing, only one of them has broken one tie rod. And yes, they did hit jumps.
Old Mar 13, 2005 | 07:24 PM
Yellr400EX's Avatar
Im juss gonna wait for the A-ARMs and put the spacers in the rear till i can get an extended axle
