How much does the cam affect jetting?
Old Mar 4, 2005 | 01:22 PM
Thumper33's Avatar
Default How much does the cam affect jetting?
The reason I ask is that I finally got a 40mm carb for my non-HO Sportsman 500, and I'm about to install it. I'm trying to figure out if I need to jet it a little leaner since it's the non-HO cam, and it's not going to let as much air into the cylinder (or out). I found stock jetting for my altitude for the stock HO is a 150 main. Should I just start there, or should I go with a 145.
Thanks,
Mike
Old Mar 4, 2005 | 05:51 PM
Oleman's Avatar
I think you should start with the same jet that's in your non-HO since you're already at a fairly high altitude. Camshafts with more lift and duration will require more fuel for greater airflow. Just how much jet you'll need will have to be determined by a plug chop, wideband or other acceptable method of fine tuning the main jet.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
