K&N Jetting Raptor
Old Mar 4, 2005 | 08:32 PM
redwingsrule05's Avatar
Default K&N Jetting Raptor
Who knows how to jet a Raptor 660R for a K&N with no airlid and full Big Gun Exhaust?
I am at about 5200 feet elevation. Thx for the info
Old Mar 5, 2005 | 01:37 AM
Chimmer's Avatar
Hmmmm........Top end: Try 160-165 or 165-170 Mikuni mains(maybe larger if head work done) as long as it doesn't bog on top. If it reaches peak power before full throttle, then its a lean on top. If it takes too long to reach full throttle, then its rich on top. Too rich mains also causes a little bog or stumble on hill climbs & major elevation changes. In other words, she seems to run perfect on flat trails but acts up on the hills, then jet down one size on the mains.
Mid range: Stock needles. Clips=3 each in summer & 4 each in winter. When slowly reving it thru the midrange, if it seems to hesitate & then really take off when you open the throttle, then its lean in the midrange, try a lower clip position.
Low end: Fuel screws 3 each in summer & 3.25 - 3.5 each in winter. Pilot jets = 25 each. Stock 22.5 pilot jets will work fine, just use more turns each side. When you rev it & release it, if it takes a while for the revs to drop down to idle, then its lean on the bottom end. If it drops below idle rpm after you release it, & then climbs up to idle rpm, then its too rich on the bottom end.
Have fun, experiment!
Old Mar 5, 2005 | 02:02 AM
ShadyRascal's Avatar
For 5200 feet that will be a bit rich. I run at that altitude normally and with full Yoshi and K&N with holes in airbox lid I use 150-155. I just changed to 155-160 for an upcoming trip to Dumont and that's pretty rich at my home altitude of 3600'.
Old Mar 5, 2005 | 12:03 PM
Chimmer's Avatar
He is running without a lid which is much leaner than a few holes in the lid.
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
