Master cylinder brake line configuration?
Old Mar 4, 2005 | 09:16 PM
Kahnman's Avatar
Default Master cylinder brake line configuration?
I have an HPD race quad and have a Honda right side master cylinder that I want to change. I purchased a left hand Magura master cylinder. The problem is that the Galfer pro brake line that comes up from the front "tee" block is a "Banjo" bolt. This fitting does not have a bend to it. The Honda master cylinder accepts the Banjo fitting in the front of the housing of the master cylinder, therefore not needing any bend in the fitting to the hose part of the line. The Magura master cylinder has the hole on the side,or end of the housing. If I use the same line, the line will be bend at an unnatural way and will not be correct. I need a brake line that has a 90degree bend just after the fitting into the master cylinder so that it will work correctly. I should be able to remove the line at the "t" block as it looks like a regular brake fitting. Of the Predator owners here, how does the brake line come off of the master cylinder? Does it have a bend? What is the fitting size? On both ends? The overall length? Please help me.
Old Mar 5, 2005 | 12:51 PM
Kahnman's Avatar
What, nobody can help me here?Text
Old Mar 5, 2005 | 01:10 PM
tbsleeper's Avatar
i think u should just call hpd i dont think any of us will know how to do that
Old Mar 5, 2005 | 01:13 PM
Kahnman's Avatar
He won't either. I just need to know how the brake hose comes out of the master cylinder on the Preddy. Does it come out straight with a Banjo bolt or at an angle witha Banjo bolt?
STLyamwar
Jul 25, 2020 04:44 AM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Sandman2.0
Jul 21, 2015 09:03 AM
