Newbie needs help
Old Mar 7, 2005 | 07:54 PM
BrokeYJ's Avatar
Default Newbie needs help
I am looking at buying a 98 scrambler. I went to look at it the other day and everything seems fine except the left front cv shaft has about 1/32nd in. play where it mounts to the differential. If it is just the shaft I am not worried about it but what do I look for to make sure there are no problems with the diff?
Old Mar 7, 2005 | 08:02 PM
jeffro206's Avatar
the front axles will get a little play around the yokes and shafts in the front. if its the shaft itself in the gearcase then it could be a sign of bearing wear. other things to look for: play in the swingarm bushings, bent axles, bent front drive shaft going to the front diff, these are just a few things to look for other than the obvious. if the play was alot more than you're saying then i would be concerned.
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
that1redhead
Sep 8, 2015 11:47 AM
