Vitos Degree key
Old Mar 7, 2005 | 09:03 PM
Yamahaalltheway's Avatar
Default Vitos Degree key
Hi what do i all need when i get the degree key and how hard is it to install.....do i just need to get it iam on this site http://www.magicracing.com/product.asp?itemid=42
bk
Old Mar 12, 2005 | 05:46 PM
TooFast2Pass's Avatar
To install the degree key you will have to remove your flywheel. To do that you'll need a flywheel puller that you can get for about $10 at any decent motorsports store. It is the same puller used on most Japanese dirt bikes and quads. There will be a nut in the center of the flywheel that you'll have to remove to get the flywheel off. You'll need air to bust that thing loose. A wrench will just turn the motor over even with it in gear and the rear brake applied. Once the flywheel is off there will be a woodruff key in the exposed crank. I believe that the degree key replaces the stock key.
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 2, 2015 11:15 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
