???? For Those WIth Extreme Racing Pred Brake Fix
Old Mar 7, 2005 | 09:42 PM
2004TroyLeePredator's Avatar
Default ???? For Those WIth Extreme Racing Pred Brake Fix
I emailed and asked about the kit for the sticking front brakes and they say that they send you some springs that you have to cut down until they are just right, can some one who has had it done be a little more specific and explain it a little better to me.
Old Mar 7, 2005 | 10:22 PM
RAJ's Avatar
RAJ
He is going to send you some springs that fit over the pins, you will put the springs between the the brake pads to keep them away from the rotor. I will see if I can get a pictures of them and show you, wants you see it done it's easy to do. You will have to cut the springs, they are to long.
Old Mar 7, 2005 | 10:51 PM
RAJ's Avatar
RAJ
Go down the page, and you will see the picture of it.....I hope this helps, took me for ever to find the tread again, but thats what these forums are about. Let me know how it goes[img]i/expressions/face-icon-small-wink.gif[/img]
Brake Fix
Old Mar 8, 2005 | 04:15 AM
kman01's Avatar
I was wondering if the drag causes premature pad wear. (not like I don't have enough mods to do on my bike anyway) I am sure there is some amount of wear but is it substantial? I am perfectly content with leaving it the way that it is.
Old Mar 8, 2005 | 08:16 AM
RAJ's Avatar
RAJ
I never use my front brakes when I drag, the only time I use them is trail riding.
Kman01 how do you like that carb mod? I just traded my Pure Polaris Pipe to a HMF Pipe, I wanted something different, since 3 out of the 4 Preds I ride with have them. I will get some pictures up as soon as I get it on, I also got a new seat cover, and my swing arm should be here before the weekend.
Old Mar 11, 2005 | 08:19 PM
Hey raj, wut is the compression rate of those springs? Also, i work on allison trannys and we have some pretty stiff to super flimsy springs we use in the valve bodies, maybe i can find one to work there.
Old Mar 11, 2005 | 09:41 PM
RAJ's Avatar
RAJ
All I know is if they are to strong you will not have much brake. I use my front brakes alot when I trail ride.
Old Mar 12, 2005 | 01:28 AM
yea, i use my fronts a lot as well. maybe i'll just buy the fix from extreme.
Old Mar 12, 2005 | 07:19 PM
raj, how easy/hard are the springs to compress by hand?
Old Mar 12, 2005 | 08:22 PM
RAJ's Avatar
RAJ
It's hard compress with finger's. I think he only charged me $1.00 per spring, and one spring will do both sides.
