which would i take out?
Old Mar 7, 2005 | 10:10 PM
alwaysride's Avatar
Default which would i take out?
Hey, when the time comes to adjust my belt, i wanna know wich shim to take out. Ive read nyrocs sight and have a manual but just need to know if there is a difference between the 3 shims( i think i heard there is 3) in there. what is the adjustment difference between them and what do each look like. Thanks.
Old Mar 9, 2005 | 01:12 AM
rivermud's Avatar
The shim is between the sheaves on the secondary for belt adjustment. It may be one thick one or two thinner. It will look like a big washer that fits around the shaft between the sheaves. To tighten the belt you either replace the one thats in there with a thinner one or you remove one (if theres 2) or if your belt is really loose you can remove them all for a real tight belt. I cant remove all mine or the bike will take off at idle.
