Which nitrous system to use
Old Mar 8, 2005 | 11:08 AM
Whitedog's Avatar
Default Which nitrous system to use
Ive done a search, and now I figured Id ask anyway. Wich nitrous system do you drag guys use? What are the pros and cons of the direct injection vs the boondocker. The direct injection uses an auxilary fuel line also, correct?
Is this considered a "wet" system by NOS maybe?
Does the boondocker pressurise your carb bowl? How good is this design? will it work with a Lectron?
Im already on alky, so all I want to squirt is 10-15 hp just to be safe... (safe, ha ha)
Also what about the price difference, and tune-ability of both systems?
Any input will be greatly appreciated!
Old Mar 8, 2005 | 12:29 PM
quadgod01's Avatar
my friend colby has a pretty good nitrous set up, you should use his.
Old Mar 8, 2005 | 01:54 PM
DLRPLATE's Avatar
I run a two stage nos system with a delay box on my drag snowmobile. I am spraying about 50hp. I would not put this on my quad unless I was strictly going to race. I am putting boondockers on my quad it is very simple and easy to use. There are less parts to malfunction and jetting is real easy. If you are only going to spray 15-20 its the only way to go. On my two stage I have to run 2 fuel tanks two fuel pumps, have hoses going every where. Keep it simple IMO.
Old Mar 9, 2005 | 03:55 PM
bansheeesmoker's Avatar
you cant run the boondocker on alky. you will have to run a wet system. You have to inject gas with a N.O.S. when using alky.
Old Mar 9, 2005 | 04:37 PM
DLRPLATE's Avatar
didnt even think of that. Yeah you will have to run a wet system
Old Mar 10, 2005 | 02:55 PM
Blaster500r's Avatar
You can run a Boons system with alky....There are quiet a few of them doing it... Boondockers will also tell you can too, but there are some fuel problems coming up on alky....But these are with people running 50+ shots, which is pretty good for such a simple system...
Very Nice people to work with...
Hope this helps ya out...
Old Mar 12, 2005 | 02:35 PM
DLRPLATE's Avatar
The Boon system can support enough fuel? I would be worried about that with that system.
Old Mar 14, 2005 | 02:20 PM
The boons system can supply enough fuel for up to or around 50+ shot, without any mods to the system...I'm tring a 30 shot now and right off the bat it was shooting so much fuel that my bike would just fall flat on its face.... So I'm in the process of leaning it out now and hopefully get finished tuning it this weekend...But I have a 10mill monoblock banshee motor and 40mm Packard Lectrons...So if there was a fuel issue I would no...LOL...Because my bike loves the Alky...But I have heard of people running 100+ shots with this system after they mod it...
Old Mar 15, 2005 | 11:38 PM
Whitedog's Avatar
Thanks for all the replys fellas.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 16, 2005 | 07:02 PM
mitcheal783's Avatar
ok- i've got a question now- would NOS do any good on a 2005 Yamaha Wolverine 350 4x4 :-D ? I dont think theres any real use in it on my quad (since all I do is mudride) but I think I'd be cool
