Good tire size set-up for A Lakota Sport with 13 Tooth
Old Mar 8, 2005 | 12:58 PM
BlazinBlu's Avatar
Default Good tire size set-up for A Lakota Sport with 13 Tooth
Lakota is piped, jetted and has 13 tooth counter shaft front sprocket with stock rear sprocket, have the stock 22" tires on still and want a better tire with rock and dirt flinging hook up, that wont rub the battery box. What size front should be used? I was going to stick with 22-8-10 up front, but what works good with 20" tires. Also live in the desert where the terrain can get rocky to sandy, to compact dirt. Thanks
Old Mar 8, 2005 | 06:02 PM
holeshotz8436's Avatar
i would go with razar2's. They are 6 ply and have a deeper tread than the regular razars and for the front razar2's or shredders would be good. the shredders are nice cuz they have a ridge in the middle for sand and with 20's in the rear, 21-7-10a would be a good size for the front
Old Mar 8, 2005 | 06:28 PM
also, where did you get ur scotts oil filter
Old Mar 8, 2005 | 09:28 PM
mahnster's Avatar
Go for 21-7-10 Razr's in the front and 20" i-Razr's for the rear.
Old Mar 9, 2005 | 04:31 PM
Vunit's Avatar
Razr are the way to go! im getting razr all around, im staying with stock size tire in the front cuz i ride trails a lot at high speeds, but im getting 20" in the back. They should be ok with the battery box, i moved mine over so im not worried about the tires hitting. Razr II are too over priced my 2 cents.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
BOBATVN
May 26, 2015 07:34 AM
lablover
Mar 12, 2000 04:03 PM
