recon help again
Old Mar 8, 2005 | 11:50 PM
fritz400ex's Avatar
Default recon help again
Old Mar 9, 2005 | 12:00 AM
fritz400ex's Avatar
on my recon theres something wrong with the gears, i dont know how to explain it but, if i hit the throttle mid or all the way it sounds like it keeps climbing rpm's but it stays the same speed, so i have to slowly add throttle to go fast. The only time it works right is right when i start it up, and ride for a few minutes, then after i ride it for alittle while it starts doing that,whats wrong and how do i fix it? sorry that i cant explain it very clearly, but please try to help because it pisses me off.
Thanks for your time[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 9, 2005 | 03:39 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Sounds like a classic case of clutch slipping to me. Your Recon is a 99, so it probably has a lot of miles on it. Autoclutches tend to get abused a lot. Clutches don't last forever. Maybe time for a new one???
Old Mar 9, 2005 | 12:04 PM
MrDumass's Avatar
Super Quad Patrol
Athens Archery Field Staff
Best lunch hour ever!
Or it could be low on oil. If it has a substantial amout missing, I bet it would slip. Dunno for sure.
Old Mar 9, 2005 | 10:08 PM
fritz400ex's Avatar
i dont think its the oil because its been doin this for quite awhile and i chage my oil regularly, so all i need you think is a new clutch?
Old Mar 9, 2005 | 11:21 PM
fritz400ex's Avatar
do i just need plates, or what?
Old Mar 9, 2005 | 11:26 PM
PolarisTheOnlyWayOut's Avatar
Well your intiall chek should be your belt...Have you ever changed it?...if not im very sure it would be tha problem...look for worn spots or small freys...those are normally signs for a new belt is in order...but if your belt looks brand new then a new clutch is the next step...but open up the clutch to see if their is any liquids in it...water, oil, or any liquid kan easily create slippage...
Old Mar 9, 2005 | 11:30 PM
fritz400ex's Avatar
im sorry for askin, but where are the belts,and where do i open up the clutch at, thanks
Old Mar 10, 2005 | 10:45 AM
Red Rider
Sorry Polaris, but no friggin BELT on any Honda, thank God! One of the primary selling points for loyal Honda riders.
Have you tried adjusting your clutch??? The procedure is in your owners manual. Do it by the book! It is the nut on the front of the engine case. If you do it wrong, you will have problems.
Old Mar 10, 2005 | 06:38 PM
fritz400ex's Avatar
alright thanks
