400ex header
Old Mar 9, 2005 | 12:23 PM
SickRider's Avatar
Default 400ex header
Ok I have a HMF slip-on and i'm planning to get a 416 this summer. Well anyway I don't want to sell my pipe and buy a full system because I'm only 14 and tryin to save some money. Well will this be okay just to leave the slip-on there? It's jetted. Another possibility is to grind out my stock header for more flow. Would this help out alot? Would I need to re-jet? Thanx
Old Mar 11, 2005 | 01:25 AM
SickRider's Avatar
anyone?
Old Mar 11, 2005 | 01:59 AM
much2fear's Avatar
From what I hear, grinding the welds out of the header is as good as an aftermarket header. I would think you would need to rejet with the header being wider because there will be more flow
Old Mar 11, 2005 | 09:13 PM
WheelieKing's Avatar
A FMF powerbomb header will work with the HMF slip-on. With the larger bore and higher compression piston your 400 will breath better with aftermarket header. I also hear that a Pro Circuit header will work.
Old Mar 13, 2005 | 08:45 PM
Honda400exyellow's Avatar
What jet do you have in now?
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bigtwin700
Sep 9, 2015 09:32 AM
