P650 and grease zirks?
Old Mar 9, 2005 | 11:36 PM
Plainsman's Avatar
Default P650 and grease zirks?
Arnt there any grease zirks on this quad? I think I need to buy a grease gun but just need a reason [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 13, 2005 | 02:16 AM
mastrblastr's Avatar
No zerks. I got 6 on mine but thats because I made my front a-arm bolts greasable as well as my swingarm bolts. Took me about 15 minutes today to grease everything as I have to remove my front bashplate, loosen the front a-arm bolts, grease them and then tighten the bolts back up. The swingarm bolts take about 2 minutes each. Works slick.
Old Mar 14, 2005 | 01:22 AM
Plainsman's Avatar
You got pics of what you did in the front?
Old Mar 14, 2005 | 10:33 AM
No pics of the front bolts. All I did was drill a 1/8 hole through the center of the bolt about half way through the length of the bolt. Drilled another 1/8 hole through the diameter of the bolt half way down the length of the bolt intersecting the hole I drilled through the end of the bolt. Drilled a 7/32 hole in the nut end of the bolt about 1/4 inch deep and tapped it for 1/4 inch thread. Screwed in a grease zerk and bob's your uncle. You have to loosen the bolt before you grease it so the grease has somewhere to go or you can pump your brains out and nothing will happen. If you look in my pics you can see how I did the swingarm bolts. Basically, I did the same thing with the front bolts.
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
