700 V force Belt Replace
Old Mar 10, 2005 | 11:33 PM
700's Avatar
700
Default 700 V force Belt Replace
My 2004 V Force has the belt light on (How do I reset it?). I want to replace the belt but am not sure wheather to have a dealership install it or do it myself. If I perform this myself how difficult is it? Exactly what tools do I need (from Kawasaki etc, and the price)? Secondly, do you reccomend a clutch kit If I only trail ride, if so which one is the best? Last, Ever since the bike was new I had a metallic screeching sound while climbing up hills from the belt housing. I had it looked at by a dealer and they said they removed the clutch to remove a contacting windage deflector. The noise is still there, what can I do to correct this? Thanks for any help
Brian.
Old Mar 11, 2005 | 11:57 AM
tuffEnuf's Avatar
Visit the following Lots of Info
http://kod.gotdns.com
http://www.smellofdeath.com/lloydy/jetting.htm
http://www.700v.com
http://www.rittercycle.com
http://cochise.uia.net/pkelley2/sparkplugreading.html
http://www.ronayers.com/browseparts....=45023-1014+++
http://mikepenland.com
TuffEnuff [img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 11, 2005 | 08:46 PM
jpsdiving's Avatar
Good job Tuff, you have been doing good research [img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 12, 2005 | 02:09 PM
kaw700vforce's Avatar
try this site....
http://www.atvnation.com/modules/AMS...?storytopic=14
Old Mar 14, 2005 | 12:25 AM
handycap's Avatar
Pull the belt cover off and flip the belt switch on the top side of cover to the other direction.
Use a Kawie belt only, Dayco belts won't last long. No tools needed once belt cover removed.
Just watch your finger when you pull the belt off the rear clutch and turn the front while removing belt until it slides off. Install new belt on ft clutch (drive clutch) first, then put it on the rear (driven clutch) clutch a little at at time, watch your fingers, while turning ft clutch.
Check tention of belt. after belt is installed turn engine over with ft cutch until belt is at top of rear clutch.
Belt deflection inbetween clutches should be about 3/4", If the belt squeels sitting in gear, its perfect. Just put in netural when you stop. ( as long as the belt isn't 1/4 or 1/2") If the belt is too loose, then the rear clutch has to come apart and remove a shim. This takes a clutch tool, snap ring plyers and a little knowledge.
Old Mar 14, 2005 | 03:46 AM
yamahawarriormods's Avatar
MY BUDDY HAS A KFX AND HE SAID HAT THE LIGHT COMES ON AFTER 1000 MILES AND HE HASN'T REPACED IT YET AND IT MUST HAVE 2000 ON IT BYE NOW .... THIS IS JUST WHAT I HAVE HEARD
COFatboy
May 2, 2020 12:06 AM
toonces
Jul 31, 2015 09:27 AM
toonces
Jul 28, 2015 01:58 PM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
