KFX 700?
Old Mar 11, 2005 | 01:15 PM
ttaylor's Avatar
Default KFX 700?
Is it possible to put a longer rear shock on the KFX without causing problems with the shaft drive?
Old Mar 11, 2005 | 07:04 PM
BANDAMAN's Avatar
Default KFX 700?
Elka zero preload rear shock will give you more travel and a lower ride height. If you do use a longer shock, you need to be aware of the fuel tank. It could possibly rub during its stroke, especially if you ever install an IMS oersize fuel tank
