reving 400 auto
Old Mar 12, 2005 | 07:12 PM
egghead's Avatar
Default reving 400 auto
i got a new 400 auto 400 today got 8miles on it
it is reving a lot higher then my 500 cat
is this normal
thanks
Old Mar 12, 2005 | 07:59 PM
mountainclimber's Avatar
Yep
Old Mar 12, 2005 | 08:25 PM
egghead's Avatar
yep that is it
Old Mar 13, 2005 | 06:59 PM
egghead's Avatar
any one else have a reving
problem with the 400 auto
our is this
normal
400 auto 13miles
Old Mar 13, 2005 | 07:06 PM
MrTommy's Avatar
What makes you think it's a problem? Our 400's sound like they're revving high too, because they are.
I would guess that the 400's rev higher than the 500's because they HAVE to...
Now, if your belt is slipping, they may be revving higher than normal. It's too bad these things don't have tachs...
Old Mar 13, 2005 | 09:16 PM
the autos rev so high. I have a maual and an auto both 400s and the 400 screams
Old Mar 13, 2005 | 10:34 PM
MrTommy's Avatar
I'm guessing the auto's rev higher as they get going, but at 'speed' they ought to be about the same. Or not...? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 14, 2005 | 02:18 PM
well the auto can be doing 20 and the manual 40 and that is where it seems to be even in my case. The auto takes forever to get up to speed.
Old Mar 14, 2005 | 02:40 PM
Bear4570's Avatar
The trans type is a CVT = Constant Velocity Transmission. Means the motor revs faster because the belt system keeps the motor in the power band of the engine at all speeds of the vehicle. Want it to not rev so much, get a spring set and modify the clutch timing.
Old Mar 14, 2005 | 04:27 PM
hondabuster's Avatar
The motors are alot different, on the 500 and the 400. The 400 doesnt have the low end torque the 500 does, so the clutch the cvt differently. The springs, weights and cam profile are different , and that keeps the motor running in the sweet spot. Its normal, and almost everyone comments on it, when they first ride the 400.
