this doesn't sound right
Old Mar 13, 2005 | 11:32 AM
Budwsr's Avatar
Default this doesn't sound right
hey I recentlay started jetting my carbs and messed arond with the needles etc.I pretty much have it dialed in (I think)but when it idles it "misses"
sounds like it's sucking air???
do I have it to lean? or do I have a vaccum leak?
I tried filming it but for some reason it keeps giving me a 3g2 format???
anyways anyone got any ideas?
thanks
Bud
Old Mar 13, 2005 | 11:53 AM
Todd400's Avatar
Anything at idle is going to be in the pilot circuit, If you do not have a vacuum leak which is possible since the carbs have been apart and the slides out I would try adjusting your pilot air screws out a 1/4 turn and see if it clears up, If it gets better try a little more until it is right, Just dont go over 3 1/2 turns out that is about the limit, I think stock they are at 1 3/4 turns.
Old Mar 14, 2005 | 12:10 AM
tuffEnuf's Avatar
Budwsr
Ensure your Throttle slide springs are not binding, your carbs are mounted snuggly in manifold boots, clamps/nuts tight on manifold boots and all your vaccum lines are connected & routed correctly in your airbox. Double check airbox to ensure filter is clean & airbox lid clamped down correctly.
If its popping in airbox after you have backed out mixture screw you need to shim or raise your needles. [img]i/expressions/face-icon-small-cool.gif[/img]
TuffEnuff
pgamboa
Dec 24, 2023 11:52 AM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
