New Brute which spring?
Old Mar 16, 2005 | 08:53 AM
VTprairie's Avatar
Default New Brute which spring?
Hey guys buying a new brute force 750 and putting my 27 mudlites on it and going to put my cdi on the bike as well what do you suggest for a spring for the belt.I run a black and red in my 650 I don't want an engagment any more harsh then that I would like to keep it the same as stock if I can.
thanks
also my prairie came with the belt a little loose from the factory and have heard other people say the same is this a problem I should have fixed before I pick it up
Old Mar 16, 2005 | 09:10 AM
HavinSomeFun's Avatar
If you plan on using the tires from your prairie they wont fit. The brute is a Honda/Yamaha Pattern. I just learned that lesson the hard way.
Old Mar 16, 2005 | 10:17 AM
VTprairie's Avatar
I am not changing the rims I am having the dealer swap tires as part of the deal
Old Mar 16, 2005 | 05:33 PM
tuffEnuf's Avatar
VPrairie.
Save your red spring & put the stock 650 spring back in the 650 before you take it to the dealer. The red Primary spring should work just as well in your BF with the 27" tires. The Red spring will Give you more torque down low. Only takes about 15 minutes to unbutton your CVT cover and swap it out.
TuffEnuff[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 17, 2005 | 08:10 AM
VTprairie's Avatar
I am leaving my black spring in my prairie and I ordered a maroon and an almond spring from EPI so I will see which set up I like best .I am still keeping my 650 for my lady she likes to ride as well
Old Mar 18, 2005 | 12:30 AM
kawiyowee's Avatar
Are you putting stock tires on the P650? Red spring too harsh for stock tires imo.
Old Mar 18, 2005 | 08:20 AM
VTprairie's Avatar
I am having the stock tires put on the 650. I am not leaving the red spring in, I am putting the stock spring back in and leaving the black secondary in it as well
Old Mar 18, 2005 | 11:10 AM
tuffEnuf's Avatar
Good Idea Vprairie
My wife tried to rid my prairie with the red spring & scared herself. Looked like a bunny rabbit. Wheelied each time she touched the throttle. Applying the throttle gently, although it can be done, with the Red spring without wheelieing is an AQUIRED-Talent. Especially, for someone thats not use to it.[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Tuff
Old Mar 18, 2005 | 02:00 PM
VTprairie's Avatar
the plan is eventually put a little more aggressive tire on the 650 maybe holeshots or someting of that nature that is why I am going to keep the black spring in
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
