Spit and sputter Bayou 250
Old Mar 18, 2005 | 11:43 PM
fraizer's Avatar
Default Spit and sputter Bayou 250
I have a 2004 Bayou 250 that misses badly at an idle and even sometimes dies at idle cold or warmed up. Using the choke a little helps. Is it to lean? The thing only has about 30hrs. on it.
Old Mar 19, 2005 | 02:47 AM
lastcall102's Avatar
turn up your idle adjustment its a **** near your left foot if you were sitting on it turn it up a 1/4 turn at a time but dont go nuts if you hear a real difference in the idle while adjusting then you went too far
Old Mar 19, 2005 | 04:31 AM
hondabuster's Avatar
Yep, check the idle speed, and if its still missing, check the spark plug. How old is the gasoline, in the tank? It could also be the mixture screw is too lean, or the valves need adjustment.
Old Mar 19, 2005 | 09:52 AM
garrett5462's Avatar
u might wanna drain out the gas and put in frech gas. also, check the air filter, and put in a new plug. also, if it is still doing it, i would clean out the carb.
Old Mar 19, 2005 | 10:50 PM
TrailHog's Avatar
I had a '88 Warrior that was doing the same as yours, the problem was a little piece of a leaf stuck over the hole on the idle jet. Try the idle adjustment first and plugs, after idle adjustment crack open the throttle a few times to let it seat into postion.
Old Mar 20, 2005 | 08:25 PM
tuffEnuf's Avatar
Bayou 250
Might also get you a can of spray carbureator cleaner, remove the airfilter, raise the engine high rpm (At least 3/4 throttle) and spray carbureator cleaner till engine boggs (Continue hold throttle open), letengine speed speed regain/smoke clear and repeat 3-5 times then Change your plug.
Ensure air cleaner is clean/properly serviced with filter oil.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
TuffEnuff
Old Dec 5, 2005 | 04:47 PM
millerboy's Avatar
I have a 03 bayou 250 and it does the same thing. I have maybe 3 hours on it.
ReconBayou
Oct 31, 2022 05:37 PM
Bernhard
Sep 25, 2015 12:45 PM
alzgarvin
Sep 11, 2015 08:53 AM
rcappie4
Sep 9, 2015 07:04 PM
Slagpolaris
Sep 5, 2015 09:41 PM
