needle in carb <84 200x>
Old Mar 23, 2005 | 06:53 PM
paulie83's Avatar
Default needle in carb
hey i was wondering what slot my needle should be set on in the carb? also i rejetted my carb to a 115 after riding i pulled the plug and it was whitish should i go to a bigger jet? also i just got my kand n filter today will this affect my jetting? thanks
Old Mar 23, 2005 | 08:04 PM
haywoodjalikme's Avatar
Default needle in carb <84 200x>
2nd groove from the bottom for a stock motor.
Any mods may change this.
The K & N will make it even leaner than it is right now.
It depends on if its lean on the low end, mid-range or wide open throttle for what has to be changed.
Jeff
Old Mar 23, 2005 | 08:27 PM
paulie83's Avatar
the motor is bored 20 over and has a dg exhaust and head pipe? when i get to high rpms it seems to cut out a little bit?? any help is appreciated thanks
Old Mar 24, 2005 | 09:03 AM
paulie83's Avatar
anyone?
Old Mar 24, 2005 | 10:55 AM
bigblock2stroke's Avatar
Yes, try a bigger jet. Go way bigger (until plug is rich) and work your way down to the nice caramel color.
You'll need a new top end if you keep running it like you are and you'll not last very long at all with the addition of the K&N.
However, if you do burn a piston, you'll then be able to put in the high compression version, port the intake/exhaust, and get a higher lift/duration cam.
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
