Front Brakes
Old Mar 28, 2005 | 04:55 PM
Kartmann's Avatar
Default Front Brakes
Can you tell me how to change out the front brake pads on a 360?
Old Mar 29, 2005 | 05:14 PM
Kartmann's Avatar
a little help please
Old Mar 29, 2005 | 05:56 PM
400PrarieXLT's Avatar
If its anything like the P400, and I bet it is, its really easy. Just have to bend the tangs on the two bolt heads on the caliper so you can loosen and remove the two bolts. The caliper will then come off and the pads are held in place by the two bolts you took out. compress the piston back into the caliper with a C-Clamp, but take off your brake fluid cover first and wrap something around it to catch any excess fluid. Put the new pads in, put the two bolts back in and bend the tangs so they wont come loose, pump the brakes to get the firm back in them and viola. 20 minute job, both sides.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
carolinabomb
Jul 26, 2015 08:40 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
