400ex issues
Old Mar 28, 2005 | 11:19 PM
vfreak's Avatar
Default 400ex issues
i recently bought a 2001 400ex with white bros pipe k&n filter rev box and no airbox lid it ran great for about ten hours then started bogging off idle and popping when slowing down to me it is lean but i dont know why it would run fine then not. the plug looks fine and i cleaned the filter i am lost now i would greatly appreciate any help with this
Old Mar 29, 2005 | 01:43 AM
Ish416's Avatar
Sounds like the jetting is off. The temperature may have varried enough to cause that or different gas. Hard telling, just mess with the jetting a bit and im sure you will be good to go.
Old Mar 29, 2005 | 10:43 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Try the simple things first. Is the choke on? Plug could be partially fouled, try a new one in. Might even have some dirt in one of the jets.
Old Mar 29, 2005 | 10:54 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Be sure to inspect your K&N for tears and make sure it's on tight, check your intake boots for cracks and for a loose head pipe.
Put fresh fuel in. I would change the plug anyway then move to jetting if the others don't solve the problem.
Unless the plug was light grey/white?
Old Mar 30, 2005 | 10:40 PM
vfreak's Avatar
thanks guys, had a plugged jet and some bad gas now i feel stupid
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
