vforce idle
Old Mar 29, 2005 | 05:38 PM
EaPatty01's Avatar
Default vforce idle
Where is the idle adjuster? I don't have a manual yet.
Old Mar 29, 2005 | 05:50 PM
derailer's Avatar
Default vforce idle
should be on the side of the carbs. Its the cable with the black twist head on it. I would say leave it alone unless you are having big prolbems with idle and if that is the case take it to the shop and have it looked at.
Old Mar 29, 2005 | 06:03 PM
Pkspawn's Avatar
Default vforce idle
Sitting on the bike.. Right hand side.. Sits right behind the fender, around where your knees are.. Small black ****,, Just turn that to adjust the idle.. You don't want it up too high, or when you goto shift into Drive or Reverse, you will hear it make a lovely noise.
The **** snaps into a tab on the plastic, which normally breaks fairly easily and it will just be hanging there on the side.. Haha.. Should be in your User Manual.. Not the Service Manual..
Or are you thinking of the air/fuel screw on the carbs??
Old Mar 29, 2005 | 06:07 PM
EaPatty01's Avatar
Default vforce idle
nope thats what I was looking for.....and on an unrelated note, I have been having this problem where I start to rap out at low speeds. It might be bad gas but have any of you guys experienced this?
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
