Need help with reverse on a Mojave 250
Old Mar 29, 2005 | 11:24 PM
CodyRx7's Avatar
Default Need help with reverse on a Mojave 250
HELP!
I picked up a 95 Mojave 250 quad the other day. It ran fine, until earlier today. I drove it fine, and when I went to go out again, once I clicked it into 1st gear, I was in reverse somehow....
I can't get out of reverse.......and don't even know how it shifted in. How do you engage and disengage reverse? DOes it have to do with the button on the clutch lever? I can't figure this out....HELP!
Old Mar 30, 2005 | 02:24 PM
CodyRx7's Avatar
Ok,
Found out my reverse switch is missing. What does it connect to on the other end of the cable?
http://i14.ebayimg.com/02/i/03/a1/af/6a_1_b.JPG
Old Mar 30, 2005 | 04:49 PM
holeshotz8436's Avatar
it connects to a shaft, right infront of where the shift lever attaches to its shaft
Old Apr 1, 2005 | 05:09 PM
steve55's Avatar
Get an owners manual first if you don't have one. Then you'll probably have to open the little reverse side cover, clean and lube internal parts with marine grease and hook up the cable/twist ****.
I will probably work great then.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
