Dyno runs
Old Mar 30, 2005 | 10:49 PM
DSSleuth's Avatar
Default Dyno runs
Had my DS on the Dyno at TVI today. 1st run hit 53.81HP w38.67 ft lbs torque
Changed the jetting/running rich 2nd run 55.07HP w37.4 " "
Some other results from other bikes a pami 760 - 65 HP w/45 Ft Lbs torque (Parker's Bike)
TVI 770 75 HP w/53 FT Lbs Torque(Parker's Bike)
TVI 800 78 HP w/ 64 Ft lbs Torque (Gary's)
I personally don't know much about the DYNO stuff but I was very happy to get the 2 extra HP on my own Bike just by changing the Main Jet. I thought I would just share the other results of the DS's done recently. I have my charts and with try to scan and post.
Old Mar 30, 2005 | 10:57 PM
thumper650's Avatar
Default Dyno runs
who is parkers bike
Old Mar 31, 2005 | 12:24 AM
thebigshow's Avatar
Default Dyno runs
what is different on parkers 770 and his 760 to make a 10 h.p increase?
Old Mar 31, 2005 | 12:36 AM
CountryJoeGlass's Avatar
Default Dyno runs
DSSleuth what is the base line on the 55HP run? What are you running?
Old Mar 31, 2005 | 01:35 AM
sandbomber's Avatar
Default Dyno runs
Originally posted by: thumper650
who is parkers bike
Parker now has my 770, What did it dyno at before tuning[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 31, 2005 | 09:25 AM
Pellter's Avatar
Default Dyno runs
Hey dsseulth was do u have in ur ds?
Old Mar 31, 2005 | 10:41 AM
busmechanic's Avatar
Default Dyno runs
I did not know they had a dyno out there. another item on my "things to do list"
Old Mar 31, 2005 | 12:13 PM
DSSleuth's Avatar
Default Dyno runs
I'm am running a Hi comp Piston in the stock cylinder, shim under valve, 110 cams, stock carb, MBRP slip on pipe, K&N filter, stock air box w/ the lid on, vortex ignition.
the 760 is all Pami, The 770 is all TVI, both bikes have the same carb. I don't know what the exact differences are.
Once I get the a-arms back from the chrome shop I will put my wife's 720 on the Dyno!!!!
I'll ask Gary what the base line is, because I don't know.
Old Mar 31, 2005 | 01:56 PM
1BigDSRider's Avatar
Default Dyno runs
Sandbomber, were you running duels, lectron, or other carb on your 770?
Old Mar 31, 2005 | 02:54 PM
shmee's Avatar
Default Dyno runs
boy thats good numbers!! for what you have. i only have 52hp!! lol...
