grinding noise
Old Mar 31, 2005 | 08:40 PM
glassman181's Avatar
Default grinding noise
My nephew has a 2004 trx400 electric shift on the last couple of rides it is making a grinding sound when going around corners it used to do it if it was on a big lean going in or out of a hole now it grinds just going around a tight corner any ideas what it is
Old Mar 31, 2005 | 09:18 PM
Polaris500HO4x4's Avatar
bad ball joint and the cv joints are rubbing... just a thought
Old Apr 1, 2005 | 10:52 AM
TRIPLELSTROKER's Avatar
Sounds to me like you have a bad wheel bearing. When you go off camber or around a turn it throws extra weight to the opposite side. Thats a good sign that you have a bad bearing. Lift it off the ground with a jack if you have one and you will possibly feel loose motion in the wheel that has t he bad bearing.
Old Apr 1, 2005 | 08:33 PM
pat89's Avatar
It does sound like a wheel bearing. If so, now is a good time to upgrade to a set of Highlifter sealed bearings. To make installation easier, stick the bearings in the freezer overnight before installing to make them easier to tap in. Also, FYI If they drop right in without any resistance you probably need to replace the knuckle assembly.
flyin-lowe
Dec 1, 2017 03:18 AM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
