Keihin 42mm 450R carb - Poor Man's upgrade on DS?
Old Apr 1, 2005 | 01:47 PM
PredFan's Avatar
Default Keihin 42mm 450R carb - Poor Man's upgrade on DS?
Guys, I don't have a DS I have a Predator. But we share the same carb - the CV Mikuni BSR42. Us predator owners have found a cheap upgrade for performance is adding a stock Keihin 450R carb. This carb is a steal at only $165 new through servicehonda.com. Used, you could probably buy one for $100. It is a 42mm pumper carb too, with a forced-slide that opens with the throttle, not CV style slide. On the predator, this carb mounts like a factory installation! It bolts right up to the manifold and intake. It has a carb-mounted choke lever that is accessable, and you can jetthe needle and main, while still on the bike.
I'm not claiming that this is better than an FCR style carb, or a Lectron for top end performance, but for my quad (bolt on's only) and my style of desert riding, duning, etc. Dollar-for-dollar this is the best mod I've done to my predator. This is on par with piping my quad, in terms of performance and the throttle response is unreal. I've looked around for other carbs, and I still can't believe how cheap this is.
Anyway, the DS is the perfect quad to try this out on, and I'm curious if you guys would be as happy as I am with this cheap upgrade. Anybody try this out yet?
Old Apr 1, 2005 | 01:57 PM
sam's Avatar
sam
I have not heard of any one doing this yet but what you have done I have, also I just head of a guy putting that carb on a z400 w/ a 450 kit. Good info !!
Old Apr 1, 2005 | 02:10 PM
Freakneh's Avatar
No doubt man, thanks for sharing!!!
Old Apr 1, 2005 | 09:00 PM
SANDMAN430's Avatar
i've been hearing good thing for the 400 ex with that carb.
Old Apr 2, 2005 | 12:13 AM
SPARKY4Q2's Avatar
COOL! Im looking for a differentt carb. Will my throttle cable hook up to that? I think i might order one this weekend. Thanks for the info PredFan[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 2, 2005 | 12:50 AM
Freakneh's Avatar
SANDMAN430, what have you heard about this carb and the 400EX? I have an 400EX too, and that would be a really cheap upgrade if it works!!!
J.
Old Apr 2, 2005 | 01:03 AM
PredFan's Avatar
Most people are buying a Honda throttle cable & Thumb throttle, some have clamied to use Yamaha thumb and cable. I modded my stock predator cable and use that. This is a wise investment. I had the carb slide mod, hi-po needle, etc....that set up is a joke compared to the response of this carb. The guys putting these carbs on 400ex's generally have them bored/stroked....it might be too much carb for a stock bore 400ex / Z400....not sure though.
Old Apr 2, 2005 | 01:35 AM
Freakneh's Avatar
Your probably right about it being too much for a stock 400EX. I'm thinking about doing alittle "refreshing" to both my DS, and the EX. I have a 2000 DS, and it just doesn't have the power that I think it should have. It's seen alot of use, so I'm sure it need's some TLC. My EX is basically for the MX track, so I'd like to do a 440, or bigger. Kits for the EX are pretty cheap, and it's a really easy motor to work on. A cheap carb would be a good start!!!
J.
Old Apr 2, 2005 | 01:12 PM
JSsDS's Avatar
Great info PredFan, this is what the forums are all about.
Not sure about the 400EX but the Z400 (KFX400 in my case) has a BSR36 CV carb. Same as the Pred and DS only smaller. I think it would be too big for anything less then a big bore with cams IMO. I wouldn't mind trying it on my stocker though...you never know, for 165.00 its worth a try.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 2, 2005 | 06:07 PM
BlackHawk's Avatar
That being a stock carburetor, with stock thumb throttle etc. would also be a really nice 'girls' upgrade. You know guys, you've got a quad that a girl rides but they complain the TM45 or Lectron thumb tension might be too much? If the Keihin adds a few ponies but keeps a stock throttle feel, that could be a very good upgrade - low cost to boot! Now Bombardier should consider that carburetor for a stock DS (assuming it does actually perform better.)
