Sunken Prairie
Old Apr 1, 2005 | 05:51 PM
maddog56's Avatar
Default Sunken Prairie
Sunk the prairie out of sight the other day. Changed the oil and filter, dried the bike out, checked connections, and cleaned and oiled the air filter and dried out the airbox. New plugs too. Now it will roll over, but it doesnt fire. Any thoughts?
Old Apr 1, 2005 | 06:24 PM
jpsdiving's Avatar
yup, scuba lesson's Mike. check your cdi( I have a spare you can try if you want)[img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 1, 2005 | 08:58 PM
HavinSomeFun's Avatar
We did this to one a few weeks ago, it was completly under for 15 minutes or so. We did all the same stuff you did and we also drained the Carbs (little allen head screw on the carb) had to drain all the gas. after we put fresh fuel in it fired up. We had to run it for awhile then it cleared up and is still running great!
Old Apr 1, 2005 | 09:52 PM
grizzkiller's Avatar
yes, havinsomefun is right on. take out that little allan head on the carb, drain out the fuel in the carbs. we had the same problem, changed the oil, took out the plugs, it would turn over but not catch. soon as we undid the carb drain all was good. we did all of this on trail when it was like 30 degrees out, it was so much fun, hehe[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 2, 2005 | 08:56 PM
maddog56's Avatar
Well we dried her out a little more and opened up the 2 allen screws. The first was dry, but the second was pretty full. Started up great! Going to change the oil and filter again after we let the engine run a bit.
Thanks guys, and thanks for the offer jps. Glad I didnt have to take you up on it.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 2, 2005 | 09:05 PM
Don't be surprised if it starts running like crap for awhile, then runs good. It will probably do this until you run a few tanks of gas through it. If it decides not to start one time just drain the carbs again.
Old Apr 2, 2005 | 09:06 PM
jpsdiving's Avatar
Mike I am glad that your problem was small. Good to hear you are up and running again. The offer is always open if you need help[img]i/expressions/face-icon-small-cool.gif[/img]
Old Apr 2, 2005 | 11:53 PM
maddog56's Avatar
Much appreciated Patrick. I'd be happy to help you in any way I can as well.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 3, 2005 | 01:42 AM
Plainsman's Avatar
Thats cool. And I was worried about a little water in the CVT [img]i/expressions/face-icon-small-smile.gif[/img] I only was up to the racks for a couple seconds.
Maddog, did the engine get killed by water or did you shut her down before hand?
So when the Prairie goes swimming should you change the diffs? I just looked at mine and didnt see any water floating so I left it.
Is there suggestions on protecting the CDI in advance?
Thanks guys!
Old Apr 3, 2005 | 01:51 AM
maddog56's Avatar
The front end sunk out of sight but the exhaust didnt go under so it was shut off when it was obvious it wasnt coming out on its own power.
My suggestion is to hit each plug with dilectric grease, seals them just about as well as you can without compromising the usefulness of a plug.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
