Lowering Ds with 400ex shocks?
Old Apr 3, 2005 | 12:46 AM
c5ls1vette's Avatar
Default Lowering Ds with 400ex shocks?
I did a search and found that some have lowered the front of the ds650 by using stock 400ex shocks.
How much does it actually lower it using these shocks and are they an exact fit.
thanks
Old Apr 3, 2005 | 08:16 PM
JDsBusa's Avatar
You will have to grind the eyelets on the shocks and the shock bushings to make them fit like the should, check my pics, I should have a pic of mine at the track w/400ex shocks.
Justin
Old Apr 3, 2005 | 11:02 PM
c5ls1vette's Avatar
thanks for the response, that is exactly how far I need to lower the front to match the back of mine.
If you don't mind I have a couple of questions:
So you are saying that I need to grind the bushing out to make it bigger so the bolt will fit right?
Also do you know if 300ex shocks are the same as 400ex shocks lengthwise, the reason I ask is because there are some for sale on ebay right now cheap. If not I will try to find some used 400ex shocks.
And what did you do to lower the back? I just took out the top red spring and lowered it all the down, it dropped my bike about 4".
thanks, Brandon
Old Apr 3, 2005 | 11:46 PM
DS650power14's Avatar
no the 300ex shocks are shorter.
Old Apr 4, 2005 | 12:04 AM
c5ls1vette's Avatar
thanks
exmotocrosser
Sep 13, 2019 06:12 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
