stock to a stage 2 or 3, well it's done anyhow
Old Apr 4, 2005 | 10:27 PM
stockbomb's Avatar
Default stock to a stage 2 or 3, well it's done anyhow
I just finished putting the old girl back together, she got a new 14:1 piston, web 109 cams, a ported head with 37mm intake valves, ported and port matched intake bored to 46mm at the throat, and still running the stock carb and pipe with end cap. I started her up and let her get warm twice, but have not ridden her yet. I can't wait to get on the gas, I am currious what kind of horse power numbers she'll be producing? anyone have an idea?
Old Apr 4, 2005 | 10:38 PM
H's Avatar
H
Low 50's. get a different carb for a noticeable improvement. The stock pipe with end cap isn't loseing more than 1.5-2 hp above 6500 rpm but you'll lose torque everywhere. JMO.
Old Apr 4, 2005 | 10:56 PM
shmee's Avatar
to see full potential you need the carb and pipe. but will still run good the way it is.
Old Apr 4, 2005 | 11:14 PM
H's Avatar
H
I personly have seen a full blown stage three with a stock carb and pipe with end cap all it put out was low 40's on the dyno. with the addition of ported intake and tm45, HP was up to 50. the motor needs to breathe. let it flow, it will run a lot better.
Old Apr 5, 2005 | 07:11 AM
stockbomb's Avatar
well the carb will be next, I wanted to do all the motor mods while it was apart. I don't know what carb to run tm45,46hv, or tm48. The mikuni's are more affordable, is the lectron worth the extra cash?
Old Apr 5, 2005 | 09:06 PM
thebigshow's Avatar
ive run just about every carb but the tm 48...in my opinion the lectron is worth EVERY pennie...it is the most explosive carb i have every used on my ds..pulls like a freight train....
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
