XCTs lose air
Old Dec 28, 1999 | 10:02 PM
SportKod's Avatar
I have new Holeshot XCTs on the new ITP T-9 Edge rims. I love 'em, but now that my riding is down to once or twice a week due to weather, the fronts go flat thru the week. I've heard this is a common problem with the XCTs, and slime won't help. Any info?
Old Dec 28, 1999 | 11:24 PM
Design_Engineer's Avatar
Ride more!!! Tires tend to do that. Your best bet is to just fill them up with more air when ever you go riding.
Evan Johnson 99 400EX 88 LT250R I apologize ahead of time for my bad spelling/typing
Old Dec 29, 1999 | 12:35 AM
hot_shoe_cv's Avatar
SportKod,
Tubeless tires are inherently leakers. Unlike car & truck tubeless tires,ATV tires are designed to run at very low psi. Any deformity in the bead area of the rim, rust spots,dents, etc. will cause a break in the seal. I ride at least every Sat & sun and Invariably have to re-inflate one or two of my Bandits to the 6 psi I run so you shouldn't fault any brand of tire as being leakers.
One suggestion if you feel it worth the time:
Deflate any tire which you feel leaks excessively, take some brake fluid and pushing the bead away from the rim as much as possible, apply the brake fluid to the entire circumference of the tire. Re-inflate the tire to 10 psi to seal, & then deflate to your normal pressure. This isn't a guarantee, but it often stops rim leaks.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Dec 30, 1999 | 06:40 PM
slotcar's Avatar
Read on the side of the tire for the max bead seat pressure.
I wouldn't go any higher than this to seat the bead.
It is usually 20-27 PSI
AMA 99 Sportsman Any Questions...ASK
P.S. Remember to keep your fingers away from the seating bead...When the bead pops in you don't want your fingers in the way. (It is usually violent)
[This message has been edited by slotcar (edited 12-30-1999).]
Old Dec 30, 1999 | 08:29 PM
Mike Chero's Avatar
SportKod,
I had the very same problem you have just stated with my old Holeshots. The best thing to do is to take them to a place that does tires. Have them take the tires off the rim and polish up any burrs on the valve stem hole and look for the same on the seating area. Then have them apply some tire seating goo. This worked wonders with my old Holeshots.
Mike Chero 97 Polaris Sport 400L/ 97 Polaris Trailblazer 250ES
<A HREF="http://users.penn.com/~hal9000/mikeetta.html">MIKE & CELESTE'S ATV PAGE </A>
[This message has been edited by Mike Chero (edited 12-30-1999).]
Old Dec 31, 1999 | 12:19 AM
THEXOTIC1's Avatar
I have had the same problems with itp holeshots i have them mounted on itp rims not the new style and also on Dougles .190 and on 10" champion beadlocks they all leaked over time Then i fixed the tires with a $10 tube in each And so far no leaks just a thought for the tires that leak
Alex
Old Jan 1, 2000 | 04:07 PM
eeveslage's Avatar
hot_shoe_cv I would like to thank you for making that post. I have bought Holeshot XCs,s and had them mounted on the stock 400ex rims about 4 months ago and the had leaked ever scince. They would go completly flat over night. Itried the thing with the brake fluid and it has been 4 days now and no leakage! Does the brake fluid make the tires seat beter or what?
Thanks Eric Eveslage
Old Jan 1, 2000 | 07:06 PM
eeveslage,
As I pointed out in my original reply, the brake fluid trick doesn't always work, but I'm glad it did the trick ( ) in your case. I believe the fluid just softens the rubber enough in the bead area to allow it to seal against the rim, without harming the rubber since rubber is used extensively in hydraulic brake systems.
Old Jan 2, 2000 | 06:03 PM
this post deleted by atvbbs.
a novice atv'er who applied this suggestion would not see the intended humor herein.
[This message has been edited by atvbbs (edited 01-03-2000).]
Old Jan 3, 2000 | 01:50 AM
THEXOTIC1's Avatar
Watch out how much lighter fluid you pour i saw an atv tire blow right off the rim i would not reccommend this way of mounting tires
