13t Front sproket on Lakota
the stock is 12/43 and if you get the 13, it will give you more topend so the higher up you go the more top speed you will have. the lower you go the more bottom end you will have. check out sidewinder, sprocketspelciest, sunstar and cycleworksracing.com all have the 13t cycleworksracing, sidewinder and sprocketspeilcest give you a choice of 11 thru 16 for the front i think and 28 to 50 for the back
atv connection modified a lakota with the 13t and they gps speed tested it and it gave a 2 mph gain. i think it is worth it deffinatly, when i had my 13t i didnt even notice a loss in bottom end. Not sure about the 14t but it will proally give it 4 more mph if the 13 gives it 2. when your ready for 20 inch tires if you get em(smaller tire, more accell) you could get the 14/41 combo and it will give it a top speed of around 72mph and you will still have a great bottom end because of the smaller tire
Hmmmmm.... 72mph, that's around what my 250r used to get with a few mods. THat would be real nice on a Lakota. My brother has a 350x and is always schooling me, I should change it and not tell him, sleeper....
scott
scott
lol, get a cam, 11:1 compression piston, oversized valves or maby even a 350cc big bore and tell him its stock. Then youll really have a sleeper
Originally posted by: bammargera
wut if i put a suzuki dr 250s sprocket on my lakota? will it fit or do u have to have a special sprocket.
