Prairie 700 belt on Prairie 650
Old Apr 7, 2005 | 04:42 PM
bigwave's Avatar
From: South Central Illinois, NO where near Chicago, that's not my Illinois
Default Prairie 700 belt on Prairie 650
I remember reading somewhere a little while back that the P700 belt would work on the P650 and were a little stronger. Is that true? Can I put an 05 P700 belt on an 02 P650? Can it still be pried / turned on or do I have to remove a flywheel.
Thanks
Old Apr 7, 2005 | 06:29 PM
Al1's Avatar
Al1
I did it on my 02 650,the 700 belt is a better quality belt (IMO)I don`t even know if they sell the 650 belt anymore.
Old Apr 7, 2005 | 06:40 PM
bigwave's Avatar
OK, thanks for the info.
Old Apr 7, 2005 | 06:52 PM
MikeyBoyesq's Avatar
FYI: I gained 1 mph with the P700 belt installed on my P650.
BTW, I think its true that Kaw. stopped making the P650 belt.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 7, 2005 | 06:54 PM
Code54's Avatar
Like the others have said, yes you can. I would also look to the aftermarket, they are QUALITY belts and they will cost you far less than the factory.
Good luck
Old Apr 7, 2005 | 06:59 PM
FASTFATBOY's Avatar
yep it will work. try a dayco belt they are strong and most likely cheaper than factory
Old Apr 7, 2005 | 07:06 PM
I don't have anything against Dayco and I've never actually tried one myself...but I would suggest you stick to OEM belts b/c several folks on atv forums have reported that cogs have broken off the dayco belts for the P650/P700. I don't know if Dayco has gotten that problem resolved by now or not.
Jeff Roper
Feb 1, 2022 11:48 AM
ReconBayou
Oct 16, 2019 02:24 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
