? for predator owners
Old Apr 9, 2005 | 01:57 PM
snogimp's Avatar
Default ? for predator owners
I bought a 04 predator tld. it has a pure slip on exhaust. k and n filter. I took off the carb today to see what i was running on the main. it is a 150 main. Ive noticed through my reading on here and on predatorownwers.com that many are getting better performance with a higher main jet. I ride at about 5000 feet and above. what should I try if I will be riding mostly St anthony and local trails. also, I noticed that many have a pipe that they installed between the carb and a filter. My filter is attatched to the carb with no tube. Is there a specific reason for this? thanks.
Old Apr 9, 2005 | 03:29 PM
RAJ's Avatar
RAJ
Do you still have the stock air box? And if you are do you have any holes drilled in the air box? I'm running a twin air filter that clamps on the carb, IMO this is the only way to go. I have tried the rath intake, and did not get the trottle response that I wanted. I'm running a 170 main jet, with the stock pilot jet and 3 1/2 turns out on the air screw. I will check back later for your reply.
Old Apr 9, 2005 | 04:34 PM
snogimp's Avatar
I do not have the stock air box. all I have is a clamp on style k&n.
Old Apr 9, 2005 | 06:09 PM
Sceiks's Avatar
RAJ, could you post a pic of you air filter setup. I have a rath lookalike custiom that i dont like and am looking for other options.
Old Apr 9, 2005 | 10:35 PM
Crapo85's Avatar
You should be around 165-170 with them mods!! You are not far from me and that is what we found worked!!
Old Apr 9, 2005 | 10:47 PM
stumpjumper400's Avatar
150 is the stock main jet for sea level, there's alot of difference between 0 and air density change of 5000 feet pressure altitude. if your bike pulls good from bottom to top and has no dead spots or pops on deceleration then i'd say your running the right jetting. the only way to tell for sure is to do plug checks.
steve
Old Apr 9, 2005 | 11:02 PM
RAJ's Avatar
RAJ
I got my set up from Doug, he has a picture of his on his web site. Here is the picture.
Old Apr 10, 2005 | 10:26 AM
heatseeker8's Avatar
Raj..not sure if you covered this already..what differences have you noticed sence changing exhaust?
Old Apr 10, 2005 | 12:49 PM
snogimp's Avatar
thanks for the replies. I went to the local poo dealer and bought some jets. I picked up a 160,165, and a 170. i am going to go out today and do some playing around with it. I also noticed that polaris now makes a 11-15 tooth front sprocket selection and up to a 42 tooth selection on the rear sprocket. just some info to pass along
Old Apr 10, 2005 | 01:53 PM
Crapo85's Avatar
If you go too small of a front sprocket up front will make chain start to wear into swingarm!! I'm running 13/41 with not problems!!
