ac 650 passing gas(this one realy stinks)
Old Apr 10, 2005 | 07:37 PM
cataway's Avatar
Default ac 650 passing gas(this one realy stinks)
my cat is a 2004 and shortly after i got it i noticed gas coming out the over flow tube ,deler fix it ,to make a long storey short on the third time back to the deler he replased the carbs. but today more gas is runing out the tube .i did however get it to stop by slaming it down kinda hard. so what is the right fix ? and dont tell me to ride slower its just not going to happen.
Old Apr 10, 2005 | 07:55 PM
Bear4570's Avatar
Is this the tank vent or the drain for the air box or a tube off the carb?
Old Apr 11, 2005 | 06:27 PM
cataway's Avatar
i wish it was one of thouse things but i have to belive it something internel,as thats what it was the first time.
Old Apr 11, 2005 | 10:11 PM
limrok's Avatar
my wife's 400 did the same thing it was something in the carb..........we were out on the trail and had to shgut the gas off and get it started and it cleaned itself.........no trouble since
Old Apr 12, 2005 | 12:37 PM
Speedwerx's Avatar
If I'm uderstanding you correctly it sounds like your needle and seat are leaking or are shot. Did you quad sit in the garage all winter with gas in it by chance?
Old Apr 12, 2005 | 02:00 PM
limrok's Avatar
speed..........this happened last fall befor i put it away for the winter.........now i have it in the shop as i have no top rpm..after about 1/2 throtle it act like the rev limiter is stopping it from opening up i tryed cleaning the carb but no luck,,thats after we rode about 50 miles on sunday
will let u all know what it is
Old Apr 13, 2005 | 05:11 PM
cataway's Avatar
i agreay it has to be the needle &seat but why dose it stick and no it is not bad gas it only happens after a fast rough ride or after a jumb even a wheele will make it to start or stop flowing.iwant to think that the flot hight is not set right .do i raise or lower and how much ?
Old Apr 13, 2005 | 09:51 PM
WhoDatInDaMud's Avatar
How much gas are we talking here? A constant flow or a few dribbles?
Does is ever stop leaking over a period of time sitting?
Have you tapped the carb to make it quit leaking?
bouncing the quad from coming off a wheele changes the leakage - indicates a stuck float or possibly something under the float. or the float limits are off.
That would explain your loss of power also - fuel starvation from the float not moving enough.
(Had that happen in an airplane once - turned out to be a rolled up ball of foil from a Marboros hard pack - made that airplane ride interesting)
Old Apr 14, 2005 | 03:03 PM
cataway's Avatar
ho it runs out at a good flow the worst thing is you dont know your losing gas then your to far from the car to get home on what you have left . i have also learnd that the seat can not be replaced .i whould like to know the proper high to set the flot
Old Apr 14, 2005 | 03:28 PM
Bear4570's Avatar
Fast, rough ride = strirring the trash on the bottom of the tank up and it runs down into the carb. Install an inline fuel filter and I bet the problem goes away, best to pull the tank and flush and clean it out real good. Dirty gas and no filter are the two biggest problems seen anymore. The refineries do a poor job, the distributor won't clean his tanks (cost money) and the stations just pass the dirt along. Then the public gets to deal with it. Install a filter and have the tank check real close. The carbs still need cleaning but if you don't filter it you will just have to do it again.
