tm 45 manual guide ?!?!?!
Old Apr 13, 2005 | 11:59 AM
denongt's Avatar
Default tm 45 manual guide ?!?!?!
i buy tm45 ron wood
i install it today and i have alot of problem..... i can drive well
i need user guide plz.....wher i can download it !?!?!?
Old Apr 13, 2005 | 12:11 PM
SCOUNDREL's Avatar
Go here...... http://www.flatlandersatv.com/tm45.htm You can get information on the TM45
Old Apr 13, 2005 | 02:09 PM
denongt's Avatar
anader web plz ......
Old Apr 13, 2005 | 10:53 PM
Hightower's Avatar
http://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
Must have adobe acrobat reader for .pdf files
give it time after you click, big file to download
RWR should have given you a copy of the manual with the carb, they usually do, if you call them, maybe they will send one.
Old Apr 14, 2005 | 11:02 AM
denongt's Avatar
is the user manual of RWR is the same manual like in the short cut.....up ...?!?!
i have 142.5 main jet and 40 air jet
i have uni air filter and hmf qs1 quite exhast
Old Apr 14, 2005 | 12:10 PM
Hightower's Avatar
yes the manual RWR supplies is the same manual as the link above, in a small booklet.
describe your problems, maybe can help.
does your carb have accelerator pump, or is it removed?
Your main jet may be too small, what altitude are you in Israel?
Is it true that Israel requires roll bar on quads? I heard this from another member from Israel.
Old Apr 14, 2005 | 12:39 PM
denongt's Avatar
YES I AM FROM ISRAEL AND WE MUST HAVE TO PUT THE roll bar BUT NO ONE DO IT .
i buy this rwr carb from another member here in the forum .
can you tell me the name of this "another member from israel " !?!?!
the accelerator pump is not connecte.
when i push 1/4 gaz (2000-3000 rpm) so is not work well ..... and when i push hard to the end in one push , the engin off.
but when i push slow on the gaz to the end he go fine.
some one told me that i have to much air and not to much fule.
when i connecet the acc pump the engin not work well and have alot of smoke .
Old Apr 14, 2005 | 09:54 PM
Hightower's Avatar
I do not remember the name of the other member from Israel - but his avatar is a yellow DS650 with a roll bar drawn on it. I don't know if he is american and in israel, or if he is from israel.
to use the accel pump, there are many pump nozzle sizes, the carbs come with #70 nozzle but the DS does better with #50 nozzle, the 70 is too rich.
with the carb jetted right and pump working, the problems you speak of are gone.
I recommend somewhere between 30 and 40 pilot jet, a #97 needle with clip on 2nd groove from top, and main depends on motor mods portwork and exhaust pipe - somewhere from 145 to 160 depending. #50 pump nozzle, with pump limit screws set to squirt from right off idle and stop squirting at 1/2 throttle.
here is picture of pumper parts and identification http://www.flatlandersatv.com/galler...album=8&pos=21
Old Apr 15, 2005 | 06:16 AM
denongt's Avatar
i have sq1 hmf exhast and stock head pipe
is it fine for this carb ?
Old Apr 15, 2005 | 11:57 AM
Hightower's Avatar
probably rich on the pilot jet if you set up to use the pumper. I would guess maybe a 30 pilot and pumper set to squirt from right off idle to 1/2 throttle. 40 pilot with also pumper may be a little rich for you
your main jet may be correct, not sure how the sq1 flows but I know its less than the race series HMF I run, common jet for race series is around 155 to 160. you can try jetting up one size at a time, and feel power gain each time, stop and go back down one size after no more gain.
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
tombrown14
Aug 31, 2015 03:53 AM
