Any one swap 04 swing arm to 00/01 yet????
Old Apr 14, 2005 | 10:21 PM
ERBEDS650's Avatar
Default Any one swap 04 swing arm to 00/01 yet????
Yep I wanna try, the alum swing arm is lighter and shorter, be nice to turn even sharper in the dunes, I'm more of a trails dune rider than a hill stormer
Old Apr 15, 2005 | 01:33 AM
JMAC650's Avatar
I swapped my 04 to an 03 style swingarm. You will need to change the upper bushings, lower shock bushings, brake caliper mount, shock, brake line, remove links from chain, and change the lower plastic sliders. I think that was all of it. I swapped mine because the front end always wanted to come up when you try and launch it or on steep hills the front end gets really light.
Old Apr 19, 2005 | 11:57 PM
Entomber's Avatar
Jmac what lower plastic sliders are you referring to? I'm going to make the switch myself. I have been told you do NOT need a new shock, you can revalve the old one to work with the new swingarm.
Old Apr 20, 2005 | 04:41 AM
JMAC650's Avatar
The lower plastic skid plates and upper chain guide. I was told the valving and spring was different so I went to elka's for an 00-03.
fd24
Jan 16, 2019 08:59 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
austinwhitton
Aug 11, 2015 06:21 PM
Bell21
Jul 28, 2015 06:52 AM
