do not run K&N filters
I was running a K&N filter for the sand and the do not seal they let sand and dirt in a bunch of sand got in and broke a ring and now my cylinder is all scored up and my piston is ruined I just got my motor built and it blew up after two dune trips
DO NOT BUY K&N
DO NOT BUY K&N
If there is a gap...I would not blame it on the K&N....you should never use a filter that has to be cobbed to get it to seal...
I'm sorry about blown engine...that's always discouraging....you really need to make sure that the boots and filter make a good tight seal.
FOR THE RECORDS GUYS, K&N FILTERS SUCK IN THE SAND AND WATER...NO MATTER HOW MUCH YOU GREASE THEM AND PUT AND OUTWEAR ON THEM...BUT THEY KICK *** ON THE TRACK...YOU NEED A FOAM FILTER FOR SAND AND WATER, SO BREAK DOWN AND SPEND THE 30$ TO GET ONE TO SAVE A MOTOR REBUILD...CLASS DISMISSED..
