Question
Old Apr 18, 2005 | 06:57 PM
kysupestar99's Avatar
Default Question
I have a 2004 polaris 330 magnum 4x4. Could anyone tell me the proper idle speed. It is not in the owners manual. I adjusted it up just a little and it starts so much better. Thanks
Old Apr 18, 2005 | 07:17 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default Question
Honestly couldn't tell you the speed on my 04. Somewhere between won't die when it's stopped and won't grind when shifting into gear. Anywhere in between those two that you're comfortable with. Sorry for the lack of technical advice, but that's how I've done all of mine.
Old Apr 18, 2005 | 09:54 PM
RobRuf's Avatar
Default Question
From the service manual it should be 1300 +/- 200 but it also says when adjusting start at 1200 check throttle cable foreplay after adjusting idle speed and adjust as necessary...
Rob
Old Apr 19, 2005 | 12:26 AM
tyler711's Avatar
Default Question
Well as long as you arent creeping when idling in gear you should be ok. And like Scootergpx said, it shouldnt grind when shifting normally.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
