Scrambler 500 2002 Best mods?
Old Apr 19, 2005 | 08:34 AM
shor133's Avatar
Default Scrambler 500 2002 Best mods?
I have a scrambler 500 and i want to make it faster. What mods should I do first? I need to buy wheels and tires what should I buy? Thanks for the help and where is the best place to buy the parts?
Old Apr 19, 2005 | 09:25 AM
XtremeSkier's Avatar
well for tires i would recommend the kenda bearclaws or ITP holeshot XCT's, but it depends on what u ride in..for mods you could start with exhuast, airfilter, and a clutch kit, i just have exhaust on my quad and it did give quite a bit more power but to get the full performance out of your exhaust u should get a clutch kit as well...heres a few aftermarket manufacturer sites
Hot Seat
HPD
Rick Ritter
Aaen Performance
Old Apr 19, 2005 | 08:25 PM
ftwflh's Avatar
If you have a 4x4 500 Scrambler your topend is limited due to the front to rear ratio but you can make it scream getting there.Main thing is a good clutch setup.start with a TEAM roller secondary and a new set of weights and a heavier spring in the primary to get the power to the ground then go with a K&N air fliter and a better flowing exhaust.Call one of the previously mentioned dealers for their recomendations on the clutch(personally I perfer RcR) On the wheels and tire any good tire that suits your needs is ok and a set of ITP T9s are great.
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
Sep 23, 2015 06:23 AM
