Drag Times
Old Apr 19, 2005 | 11:50 PM
buhjuh16's Avatar
Default Drag Times
Well tonight i went to the local drag strip to get some 'official' times. So heres my best out of about 5 or 6 runs followed by my mods.
60' - 6.105
330 - 6.178
1/8 - 9.716 @ 67.87 mph
1000 - 13.021
1/4 - 16.074 @ 71.54 mph
My mods are - 15t front sprocket, K&N, HMF Exhaust, mrhp ported match intake with razr rear tires. I'm about 5'8 140 lbs if that matters. Also I started out in 2nd gear. Are these times any good? Best i can remember when it was completely stock it ran 16.2@ 76 mph. But I believe the sprocket had a lot to do with the speed change.
Old Apr 20, 2005 | 02:21 AM
R00ST's Avatar
Default Drag Times
I have never run my quad at a strip before (or my car for that matter..) So bone stock you did 16.2? Seems like with the 15 and mods, you would be within like 10mph of top speed right around the 1/8?
Also, how do you launch? On grass with all my mods and a 15t/20 in rear tire combo, I cant keep the front end down for the life of me (launch in 2nd) so i could only imagine what the hookup would be on ashpalt.
Old Apr 20, 2005 | 09:37 AM
buhjuh16's Avatar
Default Drag Times
for some reason im the exact opposite. i cant get the front end up for the life of me other than switching from 1st to 2nd or just hammering on it in 1st and pulling back has hard as i can. But thats probably just me being little.
I was launching in 2nd gear so it didnt spin much. I actually killed it once which was kinda embarassing and led to a 19 sec run haha. But I was thinking that the mod did do quite a bit of good considering i went down .2 sec and also lost 5 mph due to the 15t sprocket. So my acceleration was alot better and im guessing my 1/8 was too.
Old Apr 20, 2005 | 10:54 AM
trentk's Avatar
Default Drag Times
i think your 15 toth spocket is actually hurting your times man.
with pipe.jet kit, k&n , stock gearing
18" tires 1/8 9.588@67.77
21" tires 1/8 9.449@68.23
i also started out in 1st on pavement
this was last year times
i will be going in a couple weeks. i let ya know what my new times are
Old Apr 20, 2005 | 03:22 PM
cdracecars's Avatar
Default Drag Times
I have been 95mph in the 1/4
Old Apr 20, 2005 | 05:16 PM
R00ST's Avatar
Default Drag Times
what bore is your DS? what ET did you get in the quarter with a 95 mph run?
I would also be interested to know what gearing you use to reach that kind of speed in 1/4.
Old Apr 20, 2005 | 05:24 PM
buhjuh16's Avatar
Default Drag Times
damn 95?
I'll throw the stock 16t front sprocket on and go next week if im off work and post new times.
Old Apr 20, 2005 | 05:32 PM
cdracecars's Avatar
Default Drag Times
my bike is a turbo bike,it was only running 3/4 throttle on that pass.
Old Apr 20, 2005 | 05:42 PM
R00ST's Avatar
Default Drag Times
Did you only run it @ 3/4 because you were testing somthing? I dont think I could ever keep out of the throttle unless someone paid me...lol
Have you dyno'd your setup? I wouldnt mind knowing what a turbo setup runs WOT on the 1/4 with appropriate gearing and tires.
Old Apr 20, 2005 | 05:50 PM
cdracecars's Avatar
Default Drag Times
i was testing a new map i had in it.how fast does your bike go?
