Trinity Exhaust Predator install question???
I installed my new trinity stage IV exhaust this evening on my 04 Predator 500 and have a question on it. Does the clamp go on the very back or does it go in the hole thats closer to the front? I had trouble getting it in the back one and finally got it to go into the one up front and I notice a little rattle at low rpms. It sounds like it might just be the exhaust breaking in, but it might be a rattle, I cant decide. And do you use any of the stock rubber washers between the frame and the clamp? Thanks for any input you might have!
My clamp is on the forward mount too. Mine doesnt have a rattle if you will but a churp. what is causing the noise is the plate that is bolted on the end of the pipe. If you take that off you will no longer have the noise your talking about. I kind of like it myself. Sets it apart from the rest. I do not have the starkarestor yet so I dont know if getting that will make the nose go away. But I know it is the plate on the end.
