sportsman speedo doesnt work
Old Apr 23, 2005 | 10:25 PM
2ridercat's Avatar
Default sportsman speedo doesnt work
Im new to the polaris family , just recently bought a sportsman 500 remington special edition. The only thing wrong with it is the speedo doesnt work. I went to my polaris dealer and he said it might be a sensor on the right front wheel , took it apart and looked at it , cleaned it and seen nothing wrong with it. Is this a problem with polarises? Has anybody else had this problem???
Old Apr 23, 2005 | 10:47 PM
SPORTSMAN70003's Avatar
Yea I have heard of quite a few going bad. Mine stopped working so I took it off and cleaned it and it started working again. Then it stop again took it off and cleaned it and it still didn't work. So I was going to order one but it started working again in the middle of a trail ride and has worked ever since.
Old Apr 23, 2005 | 11:38 PM
polarisman3's Avatar
just curious sportsman70003, was looking at your pics and what kind of oil pressure do you get while at idle? after it has been ran for along time,(fully warmed up)? and what oil press at running rpm.? thanks just curious......
Old Apr 24, 2005 | 12:04 AM
When I first start it up (cold) it reads around 40 at idle and 55 to 60 while riding down the road. After its fully warmed up it reads around 10 at idle and around 25 to 30 while riding down the road.
Old Apr 24, 2005 | 04:30 AM
jimmypsp700's Avatar
I'm on my third Hall sensor.
Easy to replace and $43 at polarisOEMparts.com or $55 from your local dealer.
Your dealer should have known if its bad or not and the other posibilities, there is a testing proceduer.
If only the speedo is out on the pod that is most likely your problem.
Jim
Old Apr 24, 2005 | 07:50 PM
2ridercat's Avatar
sportsman70003
how did you clean yours? i would like to try to clean mine first before buying a new one, if anyone knows the procedure of testing to find out if it is bad, thank you for your help
Old Apr 24, 2005 | 09:49 PM
I took mine off and cleaned it with some wd-40. Send me your email and I will send you a page telling you how to test the hall effect sensor.
Old Apr 25, 2005 | 04:29 AM
70003
Is this the procedure from tthe manual your talking about?
If not I'd like to know too.
Jim
Old Apr 25, 2005 | 09:41 AM
Originally posted by: jimmypsp700
70003
Jim
Yea its from the service manual I got. If you want it send me your email and I will send it to you.
Old Apr 26, 2005 | 03:38 AM
I have the 2002/2003 sp700 service manual .
Thanks,
Jim
