Can you put a plow on a scrambler
Old Apr 25, 2005 | 09:24 AM
Que4life's Avatar
Default Can you put a plow on a scrambler
One dealer told me you can't. Another salesman in the same store thought you could, but it would have to be a aftermarket product
would do you think???
Old Apr 25, 2005 | 11:02 AM
BubaHyde's Avatar
Yes you can. cycle country offers them. I have seen guys even put them on 250 Trailblazers.
http://www.cyclecountry.com/
The only problem is that you don't have low range and depending on how much snow youu plan to plow you can quickly burn up a belt
Old Apr 25, 2005 | 01:30 PM
BryceGTX's Avatar
Hey Que4life. The Trailblazer works great for plowing. I am not sure about the Scrammy. I suspect the Trailblazer has a lower gear ratio, given that its got a lower top speed. I have never seen the need for a low range while plowing with my Trailblazer. The key point is as long as you can creep along at 3-5 mph with your Scrammy (while loaded), I suspect you should be ok.
I hope this helps you
BryceGTX
Old Apr 25, 2005 | 08:16 PM
PaulPud's Avatar
check out my pictures then tell me you cant put a plow on a scrambler. my dealer had no problem getting it for me. its a cycle country.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
